SLD against Oracle is broken in 5.0
    Yewondwossen Assefa
    yassefa at DMSOLUTIONS.CA
    Wed Dec  5 08:05:00 EST 2007
Bart,
  I will look at this today and update the code accordingly. I will
enter a bug at that time on it.
Thanks,
Bart van den Eijnden wrote:
> Hi list,
> SLD support against Oracle is broken in MS 5.0 unfortunately. We've been
> debugging the whole morning and have identified the following problems
> in the source code (mapogcfilter.c):
> 1) the classes created by mapogcsld.c are destroyed because of the
> following call:
> line 919:
> initClass(lp->class[0]);
> the code already has a comment like which indicates this could be a problem:
>     /* TODO: Doesn't this code leak the contents of any pre-existing class
>      * in the layer???
> 2) the if clause in FLTLayerApplyCondSQLFilterToLayer never gets entered
> since bOnlySpatialFilter is always true (it is passed in as MS_TRUE
> always in the caller function, i.e. return FLTApplyFilterToLayer(psNode,
> map, iLayerIndex, MS_TRUE);)
> This means Mapserver always evaluates the query, which is very slow for
> Oracle, instead of adding a WHERE to the SQL using FILTER. For now we
> just changed the if clause:
> if (!bOnlySpatialFilter && FLTIsSimpleFilter(psNode))
> to:
> if (FLTIsSimpleFilter(psNode))
> but someone should look at this more carefully I guess ....
> 3) it's better to always use parantheses around the FILTER, since
> otherwise OR and AND won't work correctly as intended, so change line
> 929 from:
>         else //POSTGIS OR ORACLE if (lp->connectiontype == MS_POSTGIS)
>           sprintf(pszBuffer, "%s", szExpression);
> to
>           sprintf(pszBuffer, "(%s)", szExpression);
> Hope this helps.
> Best regards,
> Bart
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
