Label Cache Performance
Frank Warmerdam warmerdam at POBOX.COM
Wed Jan 3 11:40:54 EST 2007
Steve Lime wrote:
> I did think of one other gotcha. The cache is not just used for physical
> overlap, there
> are other tests applied. For example, MINDISTANCE, which filters out
> like labels based
> on proximity. That requires direct comparison of the bounding polygons.
> One might be
> able to reduce that to a test on label points (in fact that might be
> what's there now,
> I'd have to check) but that still requires traversing placed labels
> (albeit only those
> within a particular layer)...
Steve(s),
Another approach that would address requirement is a spatial index
(ie. quadtree, or just a grid) which would make it easy to find all the
labels within a certain distance.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
