RFC 33: Removing msLayerWhichItems()...
Daniel Morissette dmorissette at MAPGEARS.COM
Thu Jul 12 14:08:40 EDT 2007
Steve Lime wrote:
> The performance concern is real although I don't know how big a deal it is for all drivers. I
> believe with shapefiles you get everything anyway.  Not sure about others. How would OGR
> be impacted?
Your comment made me doubt so I ran both shapefiles and OGR data sources
in the debugger and confirmed that when rendering a map, they both load
only the attributes that are required.
In the shapefile case I believe you still need to do the file I/O to
read the full attribute record from disk, but only the values of the
required attributes are strdup'd and stored in the shape->values[] array.
OGR works in a similar way: the OGRFeature object returned by OGR
contains all the attributes but we only copy the required attributes to
the shape->values[] that is seen by MapServer.
I think the performance gain/loss would be more significant for
shapefiles than for OGR data sources for this reason.
> msLayerWhichItems sets up the item indexes and you still need that for queries since CLASSes
> come into play.
Plus, OGR uses special item indexes for some special OGR attributes that
are extracted from the style strings (OGR:LabelText, OGR:LabelAngle, and
OGR:LabelSize), so if we get rid of item indexes we'll need to think of
another way to handle that.
> One way to mitigate the performance impact might be to allow a user to explicitly set the ITEMS
> array in the configuration file. I'm hoping that with PostGIS and Oracle Spatial that's essentially
> what you do with the sub-selects. An added benefit of that would be that inline features could
> now have attributes:
> LAYER
>   NAME 'anInlineLayer'
>   TYPE POLYGON
>   STATUS OFF
>   ITEMS name, type, area END
>   LABELITEM 'name'
>   FEATURE
>      POINTS ... END
>      VALUES 'St. Paul', 'CITY', '53045098.12' END
>   END
> END
I thought about providing the ability to specify the list of items in
the layer as a possible solution as well, but then I realized that this
was a move backwards for users since MapServer used to determine the
list of items automatically, and from now on users would be required to
do that manually for all layers if they care about performance.
I find it odd for me to be arguing *for* keeping msLayerWhichItems()
since I never really understood nor liked it until today. In the
interest of getting this done for 5.0 and if everybody wants to get rid
of it then I won't object any more. I'll be happy with an optional
ITEMS...END block for those who really care about that little bit of
performance.
Daniel
Daniel Morissette
http://www.mapgears.com/
