[Fwd: Re: [MapServer] #2120: Memory Leak in msSetup()]
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Sat Jun 9 19:16:19 EDT 2007
Stephen Woodbridge wrote:
> Howard,
> Sorry can you change this again. See below.
> Also did you add msyylex_destroy();
> This breaks things as the function is not declared.
Correction: this just throws a warning. it works fine.
maputil.c:1389: warning: implicit declaration of function `msyylex_destroy'
> Thanks,
>   -Steve
> -------- Original Message --------
> Subject: Re: [MapServer] #2120: Memory Leak in msSetup()
> Date: Sat, 09 Jun 2007 23:07:36 -0000
> From: MapServer <trac at osgeo.org>
> Reply-To: trac at osgeo.org
> To: undisclosed-recipients:;
> References: <047.b6bf82e29a47a4f0f84f40105361bd34 at osgeo.org>
>  Reporter:  woodbri              |        Owner:  sdlime
>      Type:  defect               |       Status:  new
>  Priority:  normal               |    Milestone:  5.0 release
> Component:  MapServer C Library  |      Version:  5.0
>  Severity:  normal               |   Resolution:
>  Keywords:                       |
> Comment (by woodbri):
>  Howard,
>  Sorry, my bad. The patch should be as msCleanup() does not return a value.
>  #ifdef USE_GD_FT
>    gdFontCacheShutdown();
>  #endif
