MS RFC 28: Redesign of LOG/DEBUG output mechanisms
Daniel Morissette dmorissette at MAPGEARS.COM
Fri Jun 15 14:48:18 EDT 2007
Ed McNierney wrote:
> Folks -
> It would be helpful if it were possible to turn DEBUG ON right from the
> start, so debug/log messages could be generated during the loading and
> parsing of the map file.
Perhaps a MS_DEBUGLEVEL environment variable could be used to set a
default debug level for the mapObj (this value would affect only the
mapObj debug level but would not apply to layerObj debug level). As a
mapfile is read, if it contains a different DEBUG level value then the
value in the mapfile would take precedence, but at least that would
allow you to get some debug output from the beginning of MapServer's
execution.
What do you think?
Daniel
Daniel Morissette
http://www.mapgears.com/
