MS RFC 22a: Feature cache for long running processes and query processing (update)
Steve Lime Steve.Lime at DNR.STATE.MN.US
Thu Jun 28 13:26:35 EDT 2007
I'd be interested in a skeletal RFP then... ;-)
>>> On 6/28/2007 at 12:25 PM, in message <4683EEFD.9040700 at pobox.com>, Frank
Warmerdam <warmerdam at POBOX.COM> wrote:
> Steve Lime wrote:
>> I think you start bleeding over into a full-blown feature cache as described.
> That's kinda why I
>> was thinking of using the resultcache. You wouldn't even need msGetShape
> then, the shape
>> would be there for you as you rolled through the feature cache...
>> (deadline, schmeadline)
> Steve,
> But all the code that uses the resultcache would need to know to use
> the shape directly instead of calling msGetShape().  It would break
> all mapscript applications that do queries for instance.  It seems
> like a needlessly disruptive approach.
> It doesn't *have* to bleed over into a full blown feature cache.
> Best regards,
