expression in mapserver
Steve Lime Steve.Lime at DNR.STATE.MN.US
Wed May 2 01:43:25 EDT 2007
Found and fixed the problem...
Steve
>>> Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> 05/01/07 9:21 AM >>>
Stephen Woodbridge wrote:
> Yewondwossen Assefa wrote:
>> Hi There,
>> Using mapserver for svn, I am running into a problem where class
>> expressions seems to not validate : I have an expression which looks
>> like this :
>> Layer
>>  Class
>>     EXPRESSION ("[Capital]" = "1")
>>  The evaluation of the expression in msEvalExpression return always
>> false.
>>  This expression is valid with a build of Mapserver done early last week.
>>  Did some one have a similar issue ?
>> Thanks
>>  PS : I am running on windows
> Assefa,
> This is probably not you problem, but when I look at the expression
> above the following alarms sound for me:
> 1) Capital vs CAPITAL
> 2) =  vs ==
> 3) Do you need the quotes about "[Capital]"? I thought not.
> -Steve W
Steve,
  I tried it with different combination (Capital vs CAPITAL, = vs eq,
quotes and no quotes). The thing is that this same map file with the
expression works with a MapServer build from last week but not that one
I grabbed from svn yesterday. It might just be my build which is not
correct but wanted to know if others have the same issues (at least on
Windows).
Thanks.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
