Release MapServer 4.10.2 on Friday?
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Fri May 4 11:08:13 EDT 2007
The following bugs have been back ported to 4.10.x branch. Preliminary
tests have been done to insure that things work. More tests can only be
done on Monday so I am proposing that we delay the release till Monday
PM. Do people have major objections to that ?
Thanks
http://trac.osgeo.org/mapserver/ticket/1925
http://trac.osgeo.org/mapserver/ticket/2079
http://trac.osgeo.org/mapserver/ticket/2082
Bart van den Eijnden (OSGIS) wrote:
> I think the following bugs would also be good candidates to be backported
> for 4.10.2:
> http://trac.osgeo.org/mapserver/ticket/2084
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Daniel Morissette <dmorissette at MAPGEARS.COM>
> Naar: MAPSERVER-DEV at LISTS.UMN.EDU <MAPSERVER-DEV at LISTS.UMN.EDU>
> Onderwerp: [UMN_MAPSERVER-DEV] Release MapServer 4.10.2 on Friday?
> Datum: 02/05/07 17:27
>> There are a few good fixes waiting in the 4.10 branch. I propose that we
>> release MapServer 4.10.2 with those fixes on Friday of this week.
>> I start the vote with a +1.
>> Daniel
>> P.S. Here is the list of changes in 4.10 from the HISTORY.TXT:
>> Version 4.10.2
>> - Support for embedding manifests as resources for the VS2005
>> builds.(bug 2048)
>> - Changed OGRLayerGetAutoStyle not to pass NULL pointer to
> GetRGBFromString
>>    causing access violation (bug 1950).
>> - do not double-grab the row_id column in msSDELayerGetItems (bug 2041)
>> - Apply patch for bug 1990 for OS X Framework builds support for Python
>>    MapScript.  Thanks William!
>> - Added missing MS_FOLLOW constant to PHP MapScript (bug 2058)
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
