mapserver svn - AGG and PostGIS issues
Paul Spencer pspencer at DMSOLUTIONS.CA
Mon May 7 11:02:17 EDT 2007
Um.  ANTIALIAS ... do we need this keyword for AGG?  We didn't
before, so I assumed this would just happen automatically.  If this
changed then it is possible that my map file is incorrect.
Re #2, I heard a rumour that hobu may have made some changes that
might be related, I was kinda hoping to hear from him :)
Cheers
Paul
On 7-May-07, at 10:01 AM, Steve Lime wrote:
> Paul: Did you get any offline feedback? I don't really know what
> could cause #1 except
> that the ANTIALIAS token isn't being recognized. I'll check on that.
> #2 pre-dates SVN, any ideas folks????
> Steve
>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 05/03/07 4:09 PM >>>
> Hi all,
> we've been trying to build mapserver trunk from SVN into an FGS
> module and have the following issues:
> 1. agg output no longer seems to be rendering using antialiasing -
> map draws but it doesn't appear to be doing any antialiased
> rendering.  reverting to a cvs version from a week or so ago, it
> works.  No apparent errors or anything (seems to work just fine
> except for the non-aa map).
> 2. postgis layers cause mapserver to segfault.  I couldn't get
> debugging symbols into the fgs build for some reason, but I did see
> this in gdb: 0x0807fae9 in msOracleSpatialLayerGetShapeVT ().  Any
> ideas?  CVS version from a week ago has the same problem as this.
> Cheers
> Paul
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         |
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
