RFC 26 - MapServer Terminology Cleanup
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Mon May 7 20:23:54 EDT 2007
I think this would be ok.
I think most people have mapfiles for rendering, and while I'm sure
there are a bunch being used for queries, and it would be a pain to
change them, this is a onetime event to make the change and we are
probably going to make them change other things also, like
TRANSPARENCY/OPACITY, etc.
I have a lot of 2-5K line mapfiles that I will have to update.
It might be possible to write a perl script to make some or most of the
changes. Like find all TEMPLATE lines and add QUERYABLE TRUE after it.
Anyway its a thought.
-Steve W
Daniel Morissette wrote:
> Steve Lime wrote:
>> Is there a way we could do this in the code without adding a new
>> parameter? I'm
>> thinking probably not since you can use layers with WxS service
>> parameters defined
>> with the CGI or MapScript... So, I would propose recognizing the
>> template or a queryable
>> parameter.
> What if someone sets TEMPLATE "something.html" and also sets QUERYABLE
> FALSE. With what you propose the QUERYABLE setting would be ignored and
> the layer would still be queryable, right? That would be creating
> another source of confusion. I think if we add a QUERYABLE TRUE/FALSE
> setting then TEMPLATE should be treated as a simple parameter and
> queryability should be determined only by the QUERYABLE setting.
> That's just my opinion, let's see what others think.
>> Since we have a function like msIsLayerQueryable that should be easy
>> enough.
> I think there's more to do than just updating msIsLayerQueryable().
> First there is the class by class queryability that is not handled by
> msIsLayerQueryable(). I also did a quick check and there is lots of code
> that checks the layer and class template values directly and would need
> to be updated. There's also some code (mapwfs.c) that sets dummy
> template values that we could finally get rid of. I could take care of
> the implementation if you want.
> Daniel
