MapServer OSGeo buildbot configuration
Tamas Szekeres szekerest at GMAIL.COM
Mon May 14 18:45:34 EDT 2007
Steve,
I've added some steps to the telascience slave. Would you confirrm
that the stdio of those steps show the expected results?
I'm a bit uncertain about the make install step. Does it make some
system wide actions or it can be restricted to a particular folder to
be affected?
Do we have a make test target and how can I make it work?
Best regards,
Tamas
2007/5/14, Steve Lime <Steve.Lime at dnr.state.mn.us>:
> Thanks for the hard work on this. For perl on Linux the build is very straight forward:
> Perl Makefile.PL
> make
> make install
> It expects the mapscriptvars file to exist. I've only tested personally with Perl 5.8 and
> higher.
> Steve
> >>> On 5/13/2007 at 5:08 PM, in message
> <f3b73b7d0705131508o26aad0f6h305cc4702940f9f0 at mail.gmail.com>, Tamas Szekeres
> <szekerest at GMAIL.COM> wrote:
> > Folks,
> > The OSGeo buildbot for MapServer have now been set up with 1 Linux and
> > 2 Windows buildslaves (VS2003 and VS2005 builders).
> > I would encourage everyone who make a substantial change in the
> > svn-trunk to trigger a build on each platform and make sure the change
> > does not affect any of the builders.
> > The full builds are triggered automatically in every 12 hours.
> > In the future I'm planning to add the python tests to the builders and
> > I would also like to see to buildsteps for each SWIG bindings.
> > In this regard any short description about the build process including
> > the expected environment settings and software versions for the
> > various languages are highly welcomed.
> > Best regards,
> > Tamas Szekeres
