Branches
Frank Warmerdam warmerdam at POBOX.COM
Thu May 17 12:41:34 EDT 2007
Sean Gillies wrote:
> It's only easy to merge changes back into the trunk if people keep their
> sandboxes regularly updated against changes to the trunk. I learned this
> the hard way.
> Sandboxes would be good. RFC branches might also be worth some
> consideration. There is already some consensus about what does and does
> not require an RFC, and the same guidelines could be applied to what
> does or does not go straight into the trunk.
Sean / Howard,
I am leery about extensive use of extra branches, and my second-hand experience
of them in geotools is that they can lead to substantial divergence that is
hard to put back together again.
In GDAL I have introduced what is essentially a vendor branch I manage
privately in the gdal tree.  In this case it relieved substantial pressure
I was under to migrate new features back into the stable branch and gave me
a place I could test integration easily.  So I can hardly object to some use
of private branches in MapServer.
I am mildly against extensive use of branches for developing new features.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
