PHP/Mapscript: zoomscale problem
Bart van den Eijnden bartvde at GMAIL.COM
Mon Oct 8 07:17:17 EDT 2007
Hi list,
depending on the map extent, the zoomscale function will deliver exactly
that value or a value only approaching it.
This will mean that if a user wants to zoom to 1:50000 with the application,
one time he might have a layer visible which has a MAXSCALE of 50000, but
after a pan his layer could disappear again ... which is very confusing.
For instance, when I use 50000 for the scale, and run zoomscale, I get:
MAP
  EXTENT 119638.399789862 500590.444498095 130124.889552138 506876.738093905
  RESOLUTION 90.710000
  SIZE 750 450
My test script returns the following value for the scale:
50000
If I pan one time with my application, I get:
MAP
  EXTENT 117457.209919085 501372.738812169 127943.699681677 507659.032408169
  SIZE 750 450
50000.0000015
which will mean the layer will be invisible/out of scale after the pan.
The test script is very simple:
$oMap = ms_newMapObj('/data/geoservices/tmp/sess_4709facfb1052/1191837483-
2180.map');
$oMap->draw();
echo $oMap->scale;
Is there any solution for this? Using 5.0.
Best regards,
Bart
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20071008/05058c83/attachment.html
