[PATCH] make default raster image path relative to tileindex file
David Fuhry dfuhry at CS.KENT.EDU
Mon Oct 29 20:20:25 EDT 2007
The attached path makes the path of image files for a TILEINDEX layer
relative to the directory of the TILEINDEX shapefile, if the map's
SHAPEPATH is not set.
I prefer having the path fall back to the TILEINDEX file's directory
rather than the mapfile directory, because the tile index file and the
raster imagery tend to be colocated, on a large volume separate from the
mapfile.  Maybe there are some good reasons for relative-to-mapfile
behavior too, but I couldn't think of any.  Behavior is unchanged if the
SHAPEPATH is set.
The patch also removes an unused variable from msDrawRaster() and prints
out the full (instead of relative) path of a raster file if that file
could not be opened.  Printing the full path helped me with error
resolution; some might consider it less secure to be displaying it though.
-Dave Fuhry
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20071029/e52966aa/mapserver-raster-abs-tileindex.bin
