Mapserver trunk broken
Sean Gillies sgillies at FRII.COM
Wed Sep 12 10:29:07 EDT 2007
Daniel Morissette wrote:
> Frank Warmerdam wrote:
>> It is my humble opinion that we should remove this rule from the Makefile:
>> maplexer.c: maplexer.l
>>     $(LEX) --nounistd -Pmsyy -i -omaplexer.c maplexer.l
>> And instead just make a virtual target.  Something like:
>> lexer:
>> This will mean those changing the lexer need to actually manually do
>> "make lexer" but it avoids the problem we are seeing.  In particular I
>> hate the current situation which can easily bugger up my automated builds.
> I could live with this, but I wonder if there is a better fix. Note that
> we'd need the same for mapparser.c
> Also, this would have to wait until 5.2. I'd suggest you file a 5.2
> ticket. There should not be any more lexer changes in 5.0 anyway so your
> builds shouldn't be broken again for this release.
> Daniel
Add "rm maplexer.c" to the "clean" target?
Sean
