[mapserver-dev] cURL and https
    Daniel Morissette
    dmorissette at mapgears.com
    Mon Apr 21 15:51:15 EDT 2008
Julien-Samuel Lacroix wrote:
> It's possible to define where to look for the CA cert bundle or to not
> look for the certificate at all in the C code. However we can't just
> hardcode a location. The libcurl command-line interface support an
> environment variable called CURL_CA_BUNDLE, but this is not available in
> the C API. Searching for a solution I found out that other projects are
> simply implementing the support for this environment variable in their
> code.
> What other think of implementing this in MapServer? When the environment
> variable is set, use that for the certificate location.
I agree that using the CURL_CA_BUNDLE env. variable (if it is set) in
MapServer seems to be the best fix.
Daniel
Daniel Morissette
http://www.mapgears.com/
