AW: AW: [mapserver-dev] speed up layer displaying postgis-mapserver
BrainDrain paulborodaev at gmail.com
Thu Aug 21 07:46:24 EDT 2008
why you need 120 tiles at once? for what? 120... it will take a time, but it
needless in most cases to generate so many in one operation.
and why empty?
try to use Proj4 projection string instead of epsg code.
SUSANNE wrote:
> Excuse me; I sent my previous mail unintentionally!
> I am really afraid I am doing something basically wrong; but don't know
> how
> to go on.
> Thanks a lot for your help, Susanne Kalliany
> -----Ursprüngliche Nachricht-----
> Von: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von Susanne
> Kalliany
> Gesendet: Donnerstag, 21. August 2008 12:50
> An: 'BrainDrain'; mapserver-dev at lists.osgeo.org
> Betreff: AW: AW: [mapserver-dev] speed up layer displaying
> postgis-mapserver
> Sorry for being so nasty.
> I did like you told:
> LAYER
>    NAME zobject1
>    GROUP zobject1
>    STATUS ON
>    MAXSCALE 30000
>    TYPE POLYGON
>    CONNECTIONTYPE postgis
>    CONNECTION 'user=postgres password=susi dbname=tefisdb host=localhost
> port=5432'
>    DATA  'the_geom FROM zobject1 USING UNIQUE gid1 USING SRID=31282'
> 	PROCESSING 'CLOSE_CONNECTION=DEFER'
>    PROJECTION
>    		'init=epsg:31282'
>    END
> But nevertheless for drawing 4 (empty) postgis layers -120 tiles 256*256 I
> need 3.5 minutes.
> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von BrainDrain
> Gesendet: Mittwoch, 20. August 2008 21:15
> An: mapserver-dev at lists.osgeo.org
> Betreff: Re: AW: [mapserver-dev] speed up layer displaying
> postgis-mapserver
> -how did you import your layer data into postgres table? did you use GIST
> indexing?
> did you use PROCESSING "CLOSE_CONNECTION=DEFER" for your layer?
> did you reproject your data?
> cluster <gindexname> on <tablename> - just a sql command which you can run
> in context of postgis database using psql console app or pgAgmin utils or
> other software that helps pgsql developers. This command creates
> "physically-allocated" gindex which can boost perfomance for large layers.
> I have some layers with 180000-190000 polygons and mapserv draws 256x256
> tiles pretty fast for my ajax powered webapp.
> SUSANNE wrote:
>> Thanks a lot for reply!
>> I inserted following line and now postgis query works fine.
>> "DATA  'the_geom FROM zobject1 USING UNIQUE gid USING SRID=31282'"
>> But I don't get on with optimization.
>> On which place do I have to insert: "cluster gindexname on tablename" ?
>> I inserted in postgresql.conf:
>> # AUTOVACUUM PARAMETERS
>> vacuum full
>> For me it didn't make any effort.
>> And I am worried because there is only one feature in postgis table,
>> nevertheless one redraw from database needs more than 2 minute (I created
>> 30
>> png tiles 256*256 RGB 24bit).
>> I am afraid I am doing something basically wrong!?
>> Many thanks in advance for your kind efforts
>> Susanne Kalliany
>> Gesendet: Dienstag, 19. August 2008 12:31
>> Betreff: Re: [mapserver-dev] speed up layer displaying postgis-mapserver
>> 1. DATA "geom from public.construct >>>>USING UNIQUE [id field name]
>> USING
>> SRID=[your srid or -1 (not recom.)]<<<<" for all postgis layers
>> this solves problem with msPOSTGISLayerRetrievePGVersion
>> 2. I use cluster gindexname on tablename & vacuum full. +
>> http://www.powerpostgresql.com/Downloads/annotated_conf_80.html
>> SUSANNE wrote:
>>> Dear Mapserver List!
>>> I am developing Mapserver-application (ms4w 2.2.7, postgres 1.8.2) since
>>> half a year. Now some debugging and optimization work has to be done.
>>> I am doing quite well with programming, but I am not very experienced in
>>> installation - optimization issues.
>>> I would be very grateful for some hints to answer the follwing questions
>>> or how to improve performance generally.
>>> 1. How can I get rid of following error:
>>> msPOSTGISLayerRetrievePGVersion(): Query error. Error executing POSTGIS
>>> statement (msPOSTGISLayerRetrievePGVersion():select substring(version()
>>> from 12 for (position('on' in version()) - 13))
>>> I did some in internet searches but I could'nt take head or tale of it.
>>> 2. Should I increase max_buffer in postgresql.conf?
>>> I found the tip
>>> (http://mapserver.gis.umn.edu/docs/howto/optimizevector/html2pdf), but I
>>> don't have such an item in my postgres.conf file and also don't know
>>> which
>>> value I have to set.
>>> 3. How to improve displaying of 5 postgres-supported editable layer. It
>>> takes some time even when these layers are empty!?
>>> (Installation uses kaMap in javascript-php enviroment)
>>> thanks a lot, Susanne Kalliany
>> View this message in context:
> http://www.nabble.com/speed-up-layer-displaying-postgis-mapserver-tp19032703
>> p19047825.html
>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> p19076195.html
View this message in context: http://www.nabble.com/speed-up-layer-displaying-postgis-mapserver-tp19032703p19087077.html
