[mapserver-dev] unable to read TIF with mapserver 5.3dev
Guillaume Sueur guillaume.sueur at neogeo-online.net
Thu Aug 21 09:49:25 EDT 2008
hey, how do you say genius in Quebec ? It worked perfectly Daniel !
Thanks a lot !
Daniel Morissette a écrit :
> Since you've got GDAL in your build, I'd say take out the --with-tiff
> option and let GDAL handle your TIFFs... I believe the support for
> rasters through GDAL is more complete than the native TIFF support anyway.
> Daniel
> Guillaume Sueur wrote:
>> Hi list,
>> I'm facing an abnormal behaviour with MapServer 5.3dev. It's unable to
>> read a TIF file, althought is has been compiled with TIF support :
>> MapServer version 5.3-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>> SUPPORTS=WFS_CLIENT SUPPORTS=THREADS SUPPORTS=RGBA_PNG INPUT=TIFF
>> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> a shp2img on a mapfile containing a raster layer sends back
>> msDrawRaster(): Image handling error. Unrecognized or unsupported image
>> format <br>
>> drawEPP(): Image handling error. /home/guillaume/3_DATA/342421111.tif is
>> not an EPPL file. <br>
>> which AFAIK means none of the drivers was able to open the file.
>> If I run "file /home/guillaume/3_DATA/342421111.tif" I have back :
>> TIFF image data, little-endian
>> What can happen here ?
>> Thanks,
>> Guillaume
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 74 91 95 20
Site web : http://www.neogeo-online.net
