AW: AW: [mapserver-dev] speed up layer displayingpostgis-mapserver
Paul Ramsey pramsey at cleverelephant.ca
Thu Aug 21 15:34:55 EDT 2008
Back off a bit. Stop debugging your whole process and start stripping
it down into components.
How long does it take to generate just one tile? Run mapserver from
the command line to do that, so you're seeing mapserver performance,
and not conflating your control script with it.
Strip it down to just one layer in your map file. Still slow? Is one
layer in particular slow?
Turn on mapserver debugging to the max and read the timings in the
log. Is there a place the time is going?
Break it down to small parts, test each part individually. You've gone
as far as you can tinkering with map file syntax.
P.
On Thu, Aug 21, 2008 at 6:25 AM, Susanne Kalliany
<susanne.kalliany at tefis.at> wrote:
> 120 tiles are 4*30 tiles (30 tiles for covering the screen, 4 layers).
> These tiles are empty at the beginning of the project because there are no
> data. During mapping I have a routine only to update changed tiles.
> Do you have a better idea?
> Thanks for helping, Susanne Kalliany
> -----Ursprüngliche Nachricht-----
> Von: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von BrainDrain
> Gesendet: Donnerstag, 21. August 2008 13:46
> An: mapserver-dev at lists.osgeo.org
> Betreff: Re: AW: AW: [mapserver-dev] speed up layer
> why you need 120 tiles at once? for what? 120... it will take a time, but it
> needless in most cases to generate so many in one operation.
> and why empty?
> try to use Proj4 projection string instead of epsg code.
> SUSANNE wrote:
>> Excuse me; I sent my previous mail unintentionally!
>> I am really afraid I am doing something basically wrong; but don't know
>> how
>> to go on.
>> Thanks a lot for your help, Susanne Kalliany
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von Susanne
>> Kalliany
>> Gesendet: Donnerstag, 21. August 2008 12:50
>> An: 'BrainDrain'; mapserver-dev at lists.osgeo.org
>> Betreff: AW: AW: [mapserver-dev] speed up layer displaying
>> postgis-mapserver
>> Sorry for being so nasty.
>> I did like you told:
>> LAYER
>>    NAME zobject1
>>    GROUP zobject1
>>    STATUS ON
>>    MAXSCALE 30000
>>    TYPE POLYGON
>>    CONNECTIONTYPE postgis
>>    CONNECTION 'user=postgres password=susi dbname=tefisdb host=localhost
>> port=5432'
>>    DATA  'the_geom FROM zobject1 USING UNIQUE gid1 USING SRID=31282'
>>       PROCESSING 'CLOSE_CONNECTION=DEFER'
>>    PROJECTION
>>               'init=epsg:31282'
>>    END
>> But nevertheless for drawing 4 (empty) postgis layers -120 tiles 256*256 I
>> need 3.5 minutes.
>> Gesendet: Mittwoch, 20. August 2008 21:15
>> Betreff: Re: AW: [mapserver-dev] speed up layer displaying
>> postgis-mapserver
>> -how did you import your layer data into postgres table? did you use GIST
>> indexing?
>> did you use PROCESSING "CLOSE_CONNECTION=DEFER" for your layer?
>> did you reproject your data?
>> cluster <gindexname> on <tablename> - just a sql command which you can run
>> in context of postgis database using psql console app or pgAgmin utils or
>> other software that helps pgsql developers. This command creates
>> "physically-allocated" gindex which can boost perfomance for large layers.
>> I have some layers with 180000-190000 polygons and mapserv draws 256x256
>> tiles pretty fast for my ajax powered webapp.
>> SUSANNE wrote:
>>> Thanks a lot for reply!
>>> I inserted following line and now postgis query works fine.
>>> "DATA  'the_geom FROM zobject1 USING UNIQUE gid USING SRID=31282'"
>>> But I don't get on with optimization.
>>> On which place do I have to insert: "cluster gindexname on tablename" ?
>>> I inserted in postgresql.conf:
>>> # AUTOVACUUM PARAMETERS
>>> vacuum full
>>> For me it didn't make any effort.
>>> And I am worried because there is only one feature in postgis table,
>>> nevertheless one redraw from database needs more than 2 minute (I created
>>> 30
>>> png tiles 256*256 RGB 24bit).
>>> I am afraid I am doing something basically wrong!?
>>> Many thanks in advance for your kind efforts
>>> Susanne Kalliany
>>> Gesendet: Dienstag, 19. August 2008 12:31
>>> Betreff: Re: [mapserver-dev] speed up layer displaying postgis-mapserver
>>> 1. DATA "geom from public.construct >>>>USING UNIQUE [id field name]
>>> USING
>>> SRID=[your srid or -1 (not recom.)]<<<<" for all postgis layers
>>> this solves problem with msPOSTGISLayerRetrievePGVersion
>>> 2. I use cluster gindexname on tablename & vacuum full. +
>>> http://www.powerpostgresql.com/Downloads/annotated_conf_80.html
>>> SUSANNE wrote:
>>>> Dear Mapserver List!
>>>> I am developing Mapserver-application (ms4w 2.2.7, postgres 1.8.2) since
>>>> half a year. Now some debugging and optimization work has to be done.
>>>> I am doing quite well with programming, but I am not very experienced in
>>>> installation - optimization issues.
>>>> I would be very grateful for some hints to answer the follwing questions
>>>> or how to improve performance generally.
>>>> 1. How can I get rid of following error:
>>>> msPOSTGISLayerRetrievePGVersion(): Query error. Error executing POSTGIS
>>>> statement (msPOSTGISLayerRetrievePGVersion():select substring(version()
>>>> from 12 for (position('on' in version()) - 13))
>>>> I did some in internet searches but I could'nt take head or tale of it.
>>>> 2. Should I increase max_buffer in postgresql.conf?
>>>> I found the tip
>>>> (http://mapserver.gis.umn.edu/docs/howto/optimizevector/html2pdf), but I
>>>> don't have such an item in my postgres.conf file and also don't know
>>>> which
>>>> value I have to set.
>>>> 3. How to improve displaying of 5 postgres-supported editable layer. It
>>>> takes some time even when these layers are empty!?
>>>> (Installation uses kaMap in javascript-php enviroment)
>>>> thanks a lot, Susanne Kalliany
>>> View this message in context:
> http://www.nabble.com/speed-up-layer-displaying-postgis-mapserver-tp19032703
>>> p19047825.html
>>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
>>> mapserver-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> p19076195.html
> p19087077.html
