[mapserver-dev] Re: PHP_MapScript - set opacity of a styleObj
Yewondwossen Assefa yassefa at dmsolutions.ca
Wed Aug 27 08:36:35 EDT 2008
Mike,
  I have opened http://trac.osgeo.org/mapserver/ticket/2755 and I will
commit your changes.
Best Regards,
Mike Leahy wrote:
> Hello again,
> I think I answered my own question.  In php_mapscript.c, I made the
> following changes:
> - In _phpms_build_style_object, I added this:
>     add_property_long(return_value,   "opacity",       pstyle->opacity);
> - And in php3_ms_style_setProperty, I added this:
>     else IF_SET_LONG( "opacity",        self->opacity)
> I recompiled mapserver, and it works - at least I think (i.e., no errors
> when I set the property, and everything else is working as it did)...I
> still have to get the code I'm working on to render some output.
> Do these changes look okay?
> Mike
> Mike Leahy wrote:
>> Hello devs,
>> I'm just wondering if I'm missing anything (since the online
>> documentation claims to be out-of-date).  I'm trying to create a new
>> layer in a PHP_MapScript map object that has opacity set in a
>> styleObj.  But when I execute $oStyle->set("opacity",50), I get an
>> error message saying "Property 'opacity' does not exist in this
>> object.".  The same happens for transparency.  Is there a different
>> way I should be doing this?
>> Since style-level opacity is a new feature, I'm guessing it hasn't
>> made its way into mapscript yet?  If that is the case, what would be
>> needed to add this, and/or is there a workaround I that can use
>> instead?  The only alternative I can imagine at this point is to save
>> the map object to a temporary mapfile, write the new layers as text in
>> the mapfile, then read it back into a new map object.  Is that my best
>> option?
>> Thanks for any suggestions,
>> Mike
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
