[mapserver-dev] How to reset the projection object for layerObj and mapObj
Tamas Szekeres szekerest at gmail.com
Tue Dec 2 08:58:54 EST 2008
Hi Devs,
Am I right that currently we don't have the option to reset the projection
object for  layerObj and the mapObj by using the SWIG interface?
I just wanted to  revert this object into the same state as if it was
created without specifying the projection.
Using setProjection(null) doesn't seem to be a supported option since
msLoadProjectionString doesn't handle the null argument value.
If you don't know about a workaround either, then I'm keen to modify
msLoadProjectionString in order to handle this option.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20081202/4a78ca6f/attachment.html
