[mapserver-dev] Point layers with Oracle driver
David Fuhry dfuhry at acm.org
Tue Feb 12 15:40:30 EST 2008
Daniel,
Point ordinates wouldn't ever be in SDO_ELEM_INFO; it only stores
metadata for how to interpret SDO_ORDINATES.
I'm not sure what MapServer does, but Oracle MapViewer will render a
point if the ordinates are stored in either the SDO_POINT or the
SDO_ORDINATES substructure of SDO_GEOMETRY.
Notably, 10g+ has a feature known as "oriented points", in which
SDO_POINT is null, and the (x,y[,z]) point ordinates are stored in
SDO_ORDINATES, and are followed by values (still in SDO_ORDINATES) which
describe an angle, for obvious use in labeling.
The correct behavior would be for MapServer to render the point at the
location stored in SDO_ORDINATES iff the SDO_POINT is null.
Thanks,
Dave
Daniel Morissette wrote:
> Fernando,
> I've had someone report to me that when MapServer reads point layers
> from Oracle, it works fine if the coordinates are stored in the
> SDO_POINT, but it doesn't work if they are stored in SDO_ELEM_INFO or
> SDO_ORDINATES which are apparently two other valid ways of storing point
> data.
> Are you aware of this issue? Is there a way around it or do you have any
> advice to provide to users who run into this problem?
> Thanks
> Daniel
