Antwort: Re: [mapserver-dev] Point layers with Oracle driver
umn-ms at hydrotec.de umn-ms at hydrotec.de
Thu Feb 14 04:27:56 EST 2008
Hi
I think Daniel asked, how Mapserver-users could deal with this issue in
the case, they have
no direct influence on the way points are represented in the
oracle-database.
Maybe this is a workaround:
DATA "GEOMETRY FROM (SELECT MDSYS.SDO_GEOM.SDO_CENTROID(shape)
geometry,... FROM MYTABLE  ) ...."
I didn't test it with mapserver. But the following SQL-statement delivers
"544347.756":
                                       SDO_GEOMETRY(2001, 82247, NULL,
    SDO_ELEM_INFO_ARRAY(1, 1, 1),
    SDO_ORDINATE_ARRAY(544347.756, 4350295.7)),
                                       0.05).sdo_point.x
FROM DUAL;
It seems, that MDSYS.SDO_GEOM.SDO_CENTROID converts the way a point is
represented.
Bye
benedikt Rothe
mapserver-dev-bounces at lists.osgeo.org schrieb am 13.02.2008 03:18:12:
> Fernando,
>     Good suggestion.
> SQL> select * from tt;
> GEOM(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z), SDO_ELEM_INFO,
SDO_ORDINATES)
> SDO_GEOMETRY(2001, 82247, NULL, SDO_ELEM_INFO_ARRAY(1, 1, 1),
> SDO_ORDINATE_ARRAY
> SQL> select sdo_geom.validate_geometry_with_context(geom, 0.000005) from
tt;
> SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT(GEOM,0.000005)
> TRUE
>     This one geometry in a large table in which the point geometry
> representations vary between SDO_POINT and SDO_ORDINATES.  The original
> data stored its ordinates in SDO_POINT, but a frontend app inserts new
> geometries with ordinates in SDO_ORDINATES.  The app developers
> construct Oracle JGeometry objects in java, then insert then using JDBC.
>   Obviously the process is pretty lax since the data is inserted as
> SDO_ORDINATES, and yet rendered identically by Oracle MapViewer.
>     Here's some information on their oriented point extension:
> http://download-west.oracle.com/docs/cd/B19306_01/appdev.
> 102/b14255/sdo_objrelschema.htm#CBBIGEFH
> Thanks,
> Dave
> Fernando Simon wrote:
> > Hi Daniel and David,
> >     Well, about the SDO_POINT. The Mapserver driver just read the
point
> > data from SDO_POINT, from the Oracle Spatial manual (page 2.2, for
point
> > example and figure 2-6): "SDO_ELEM_INFO and SDO_ORDINATES are both
NULL,
> > as required if the SDO_POINT attribute is specified." And the
SDO_POINT
> > topic in the manual hint that you can just store points using the
> > SDO_POINT attribute.
> >     Maybe you can force the use of the
> > SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT function to verify if the
> > geometry is valid, if it returns true and Mapserver can't draw, we
have
> > a bug :).
> >     David, about the kind of the point that you wrote, the Mapserver
> > can't draw it. I never head about it, I will read about it and other
> > things for release 11 to check new features. Now a question for core
> > developers, if I read angle data from database (like David wrote about
> > the point) can I set the angle attribute for the layer? Will work, the
> > angle?
> >     We can check about this special kind of data, but I believe that
> > Mapserver just need to draw the data/kinds/types defined in the 2-2
> > table for SDO_ELEM_INFO.
> >     Daniel, in my opinion the data that you report was wrong. You can
> > write in the Oracle forum (in the OTN page) about it, the developers
of
> > the Oracle Spatial read and reply there.
> >     Best regards.
> > Fernando Simon
> > David Fuhry wrote:
> >> Daniel,
> >> Point ordinates wouldn't ever be in SDO_ELEM_INFO; it only stores
> >> metadata for how to interpret SDO_ORDINATES.
> >> I'm not sure what MapServer does, but Oracle MapViewer will render a
> >> point if the ordinates are stored in either the SDO_POINT or the
> >> SDO_ORDINATES substructure of SDO_GEOMETRY.
> >> Notably, 10g+ has a feature known as "oriented points", in which
> >> SDO_POINT is null, and the (x,y[,z]) point ordinates are stored in
> >> SDO_ORDINATES, and are followed by values (still in SDO_ORDINATES)
which
> >> describe an angle, for obvious use in labeling.
> >> The correct behavior would be for MapServer to render the point at
the
> >> location stored in SDO_ORDINATES iff the SDO_POINT is null.
> >> Thanks,
> >> Dave
> >> Daniel Morissette wrote:
> >>> Fernando,
> >>> I've had someone report to me that when MapServer reads point layers
> >>> from Oracle, it works fine if the coordinates are stored in the
> >>> SDO_POINT, but it doesn't work if they are stored in SDO_ELEM_INFO
or
> >>> SDO_ORDINATES which are apparently two other valid ways of storing
> >>> point data.
> >>> Are you aware of this issue? Is there a way around it or do you have
> >>> any advice to provide to users who run into this problem?
> >>> Thanks
> >>> Daniel
> >> _______________________________________________
> >> mapserver-dev mailing list
> >> mapserver-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080214/6f22376a/attachment.html
