Antwort: Re: [mapserver-dev] Point layers with Oracle driver
Fernando Simon fsimon at univali.br
Thu Feb 14 11:07:35 EST 2008
Citando Daniel Morissette <dmorissette at mapgears.com>:
> Fernando Simon wrote:
> > Hi Benedikt,
> >     Yes, this is a good workaround. For MapServer, if the
> sql/query
> > returns a MDSYS.SDO_GEOMETRY the driver can read and draw it.
> >     Maybe we need to test performance, but I believe that this
> > workaround don't degrade the performance.
> >     Best regards.
> Thanks Benedikt for the suggestion, we'll give it a try.
> Fernando, would you consider adding support for reading the
> SDO_ORDINATES value when SDO_POINT is null since that seems to be a
> valid case according to this page?
http://download-west.oracle.com/docs/cd/B19306_01/appdev.102/b14255/sdo_objrelschema.htm#CBBIGEFH
> I can create a ticket for that if you want...
Daniel,
    Yes, I will add the support for this kind of point. I belive that
the ticket is the best way, we can track/log all the info about it.
No problem, you can open the ticket.
    Best regards.
Fernando Simon
  Univali - Webmail - http://webmail.univali.br
