wxs/expected/wms_cap.xml
Normand Savard nsavard at MAPGEARS.COM
Wed Jan 23 15:03:38 EST 2008
Frank Warmerdam wrote:
> Tom / Normand,
> I'm trying to run some of the wxs tests before extending them for WCS
> 1.1.
> (well I've already started to extend them)
> When I do "run_test.py wms_simple.py" I get the following difference on
> wms_cap.xml:
> warmerda at gdal64[259]% diff {expected,result}/wms_cap.xml
> 86c86
> <           <LegendURL width="20" height="10">
> >           <LegendURL width="70" height="23">
> 88c88
> <              <OnlineResource
> xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
> xlink:href="http://localhost/path/to/wms_simple?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=road&amp;format=image/png"/>
> >              <OnlineResource
> xlink:href="http://localhost/path/to/wms_simple?version=1.1.1&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=road&amp;format=image/png&amp;STYLE=default"/>
> Are these expected changes?  I'm guessing the "&amp;STYLE=default" change
> relates to the style default changes?  What about the legend url?
> Have either of you been running the msautotest/wxs suite lately?  It
> seems
> a bit crufty.
Frank,
I didn't run it recently and just did it.  I got the same results as
you.  I may check them a little bit.
Norm
