[mapserver-dev] pg_config detection in configure
Guillaume Sueur guillaume.sueur at neogeo-online.net
Tue Jul 22 09:30:35 EDT 2008
sure ! I can't login right now (server doesn't give any answer to login
attempts), but I will as soon as it awakes ;-)
another point. python-mapscript agg support is still problematic.
Workarounds exist
(http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg14120.html)
, but the straightforward
python setup.py install
builds a non-working mapscript.py :
import mapscript -> undefined symbol: _ZN3agg12g_sqrt_tableE
any new piece of informations about it ?
Thanks
Daniel Morissette a écrit :
> Guillaume,
> Could you please file a ticket? I'll take care of it.
> Daniel
> Guillaume Sueur wrote:
>> Hi list,
>> playing around with the new mapserver source, I've found something
>> annoying into the configure :
>> when you ask for with-postgis=/some/dir/pg_config, the configure
>> script finishes ok even if it had warned you that it couldn't find
>> pg_config. Worse, the final sum up indicates :
>> PostGIS support:    -DUSE_POSTGIS
>> making people think it went well.
>> Actually, there is a message in the middle of configure output, but if
>> you don't scroll up to check it, you can't know you misconfigured your
>> path.
>> Couldn't it stop on this warning, like it does for GD for instance ?
>> Thanks
