[mapserver-dev] MapServer 5.2 Beta 3 Available
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Jun 27 15:50:04 EDT 2008
Jim,
There was indeed a change in beta3 regarding TILEINDEX layers, but it
should not affect any existing indexes with SHAPEPATH set, which is
your case.  I can duplicate your error with a file structure exactly
like yours: with beta2 no error, with beta3 i get your exact errors.
Would you mind reporting this in the associated ticket?   http://trac.osgeo.org/mapserver/ticket/2369
   Also please include what OS you are testing on (I am testing on
Windows).
Good find!
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
On 27-Jun-08, at 11:54 AM, Jim Klassen wrote:
> All,
> Beta3 seems to have broken my tiled raster layers. These layers all
> worked fine up through 5.2.0-beta2. Is there something I need to
> change in my config?
> The error I get is "msDrawMap(): Image handling error. Failed to
> draw layer named 'L10'. msDrawRaster(): Unable to access file.
> L10/512000_0-1024000_512000.jpg using full path
> L10/512000_0-1024000_512000.jpg"
> In map I have SHAPEPATH set to "PWTS/2006_00"
> In the layers I have TILEINDEX "L10/TILEINDEX"
> In the tileindex I have Locations such as
> "L10/512000_0-1024000_512000.jpg"
> The file system layout is:
> ./AERIAL_2006/ramsey_2006.map
> ./AERIAL_2006/PWTS/2006_00/L10/TILEINDEX.{shp,shx,dbf}
> ./AERIAL_2006/PWTS/2006_00/L10/*.jpg
> Jim Klassen
> City of St. Paul
>>>> "Steve Lime" <Steve.Lime at dnr.state.mn.us> 06/26/08 10:00 PM >>>
> - mapshape.c: Applied patch to make the location of tiled data
> relative to the
>  tileindex directory if SHAPEPATH is not set. (#2369)
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
