[mapserver-dev] mappostgis.c
Daniel Morissette dmorissette at mapgears.com
Tue Nov 4 14:23:02 EST 2008
Paul Ramsey wrote:
> FYI, as threatened, I have updated the postgis driver in trunk rather
> substantially.  The binary cursor is gone, the SQL generation is a bit
> more modular, much of the code duplication is removed, some memory
> leaks are removed, I'm sure some others have been added (valgrinding
> is still on the to-do list). In general the complexity is a lot lower
> without the binary cursor, so it's all worthwhile.
Awesome news! Thanks Paul!
> I put some prototypes and structs in mappostgis.h, so I could bring
> them into my unit tester more easily. The other thing on my "unit
> testers wishlist" would be having the mapserver Makefile put things
> like the INCLUDE paths and LIB flags and -D lists in a place where
> other Makefiles could import them. For external apps making use of
> libmapserver.a, it would be quite handy.
The mapserver-config script should provide all that you need. If
anything is missing then that's probably the place to add it.
Daniel
Daniel Morissette
http://www.mapgears.com/
