[mapserver-dev] ms rfc 48: adding a type keyword to the styleblock
Tamas Szekeres szekerest at gmail.com
Thu Nov 6 18:39:42 EST 2008
Thomas,
I don't mind implementing a limited version, however the syntax of the
expression should be finalized without requiring to do backward
incompatible changes when extending the geometry processor in the
future.
Additionally you should consider the desired impementation in such way
which doesn't require to restructure the code when implementing the
things further.
This RFC should mention which functions will be affected in this
regard, when such an enhancement will take place in the future.
Best regards,
Tamas
2008/11/6 thomas bonfort <thomas.bonfort at gmail.com>:
> On Thu, Nov 6, 2008 at 22:10, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>>  I'm not sure if anyone would want to use these
> the original intent of this rfc was to have something a bit more
> generic than directly adding arrowhead support, so this is getting a
> bit unwieldy  :)
> The idea of having a single geometryexpression keyword leaves many
> possibilities as to the transformations of the original geometry, do
> you think that the nested expression stuff could be postponed? (I have
> limited time and ressources to get this in, but the concept appeals to
> me so I'd like to dig in further in the longer term)
> cheers,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
