[mapserver-dev] NODATA value problem
bartvde at osgis.nl bartvde at osgis.nl
Mon Nov 10 09:53:09 EST 2008
Hi list,
I am using the GDAL ArcSDE raster driver, but the NODATA values are mapped
to 0. I only found this post from 2006:
http://lists.osgeo.org/pipermail/gdal-dev/2006-December/011195.html
but could not track a bug.
Has this been fixed?
If not, would it require changes to Mapserver?
If not, would it require changes to GDAL (the GDAL ArcSDE driver says it
does not support NODATA masks, but I am not sure if this relates to my
problem)?
TIA.
Best regards,
Bart
