[mapserver-dev] Mapserver v5.2 ArcSDE point layer prob
Graham Davis gdavis at refractions.net
Wed Nov 19 12:10:51 EST 2008
I've added a bug ticket for this here
http://trac.osgeo.org/mapserver/ticket/2814
Any help would be appreciated.  Thanks,
Graham.
Graham Davis wrote:
> Hi,
> I brought this problem up in the mapserver IRC channel last week, and
> have some more info regarding it.  Basically I've built Mapserver v5.2
> for a client on Windows as they wish to upgrade from v4.10.  With the
> new version, none of the their ArcSDE point layers work.  But polygon
> and other types seem to work fine with SDE.  All of the problem point
> layers worked fine in version 4.10 (the only thing that has changed is
> the new mapserver).
> I've since built them version 5.0 for them to test with (to try and
> narrow down where the problem was introduced).  This version works
> fine for SDE point layers.  So something has changed between versions
> 5.0 and 5.2 to prevent SDE point layers from working.  The error
> message they receive is:
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named
> 'DBM_7H_MIL_POPULATION_POINT'.
> msDrawShape(): General error message. Unknown layer type.
> </ServiceException>
> </ServiceExceptionReport>
> Anyone have any idea what is going wrong, or where I can officially
> post this bug?  A snipet of the map file layer definition is
> attached.  Thanks,
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Graham Davis
Refractions Research Inc.
