[mapserver-dev] Time for a 5.2.1 release?
Perry Nacionales naci0002 at umn.edu
Wed Nov 19 15:16:48 EST 2008
+1
Alan Boudreault wrote:
> +1
> Stephen Woodbridge wrote:
>> +1
>> Kralidis,Tom [Ontario] wrote:
>>> Fair enough.  +1
>>> ..Tom
>>>> -----Original Message-----
>>>> From: Daniel Morissette [mailto:dmorissette at mapgears.com] Sent:
>>>> Wednesday, November 19, 2008 8:49 AM
>>>> To: Kralidis,Tom [Ontario]
>>>> Cc: mapserver-dev at lists.osgeo.org
>>>> Subject: Re: [mapserver-dev] Time for a 5.2.1 release?
>>>> I'd say we release 5.2.1 with what's in SVN already and those two
>>>> tickets can wait for 5.4 or 5.2.2 since if they were high enough
>>>> priority they would be fixed already.
>>>> Daniel
>>>>> Any update on this?  Looks like
>>>>> http://trac.osgeo.org/mapserver/ticket/2781 and
>>>>> http://trac.osgeo.org/mapserver/ticket/2657 are tickets of
>>>> interest to
>>>>> fix for a 5.2.1 rel.
>>>>> ..Tom
>>>>>> From: mapserver-dev-bounces at lists.osgeo.org
>>>>>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff
>>>>>> McKenna
>>>>>> Sent: Monday, October 20, 2008 10:28 AM
>>>>>> To: MapServer Dev Mailing List
>>>>>> I'd recommend the 5.2.1 release happens in the next couple
>>>> of weeks.
>>>>>> (sooner than later is better for me) Thoughts?
>>>>>> -jeff
>>>>>> Steve Lime wrote:
>>>>>>> It's ok with me. Any chance of sneaking
>>>>>> http://trac.osgeo.org/mapserver/ticket/2781 in?
>>>>>>> Steve
>>>>>>>>>> On 9/29/2008 at 8:17 AM, in message
>>>> <2DC5CCA14756424BBBEE8B4B2E4A682F03BCC59B at ecburexch1.ontario.int.ec.g
>>>>>> c
>>>>>>> .ca>, "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> wrote:
>>>>>>>> I would like to see
>>>>>> http://trac.osgeo.org/mapserver/ticket/2657 fixed
>>>>>>>> (I believe the patch will do it), otherwise, I thank 5.2.1
>>>>>> this week
>>>>>>>> is a good idea.
>>>>>>>> ..Tom
>>>>>>>> From: mapserver-dev-bounces at lists.osgeo.org on behalf of Daniel
>>>>>>>> Morissette
>>>>>>>> Sent: Mon 29-Sep-08 09:15
>>>>>>>> To: 'MapServer Dev Mailing List'
>>>>>>>> Subject: [mapserver-dev] Time for a 5.2.1 release?
>>>>>>>> We seem to have a good set of fixes in the 5.2 branch in
>>>>>> SVN. What do
>>>>>>>> you all think of a 5.2.1 release this week with what's in
>>>>>> there now?
>>>>>>>> Daniel
>>>>>>>> Current Version (SVN branch-5-2)
>>>>>>>> - Fixed bug when QUERYMAP hilite color is set and the
>>>>>> shape's color in a
>>>>>>>>    layer is from a data source (#2769)
>>>>>>>> - PHP paste image should also work with AGG (#2682)
>>>>>>>> - Correct allocation error in mapmssql2008.c (#2768)
>>>>>>>> - Removed comma to correct WCS 1.1 Coverages formatting
>>>> in payload
>>>>>>>> directory.
>>>>>>>>    (#2764)
>>>>>>>> - Correct bug when LABEL_NO_CLIP in combination with
>>>>>> minfeaturesize
>>>>>>>> (#2758)
>>>>>>>> - Fix a label size computation for AGG bug when
>>>>>> scalefactor is used
>>>>>>>> (#2756)
>>>>>>>> - Got rid of misleading errors about OWS SERVICE not being
>>>>>> compiled in
>>>>>>>>    when a OWS request is sent that includes mode=map (or
>>>>>> other mode value
>>>>>>>>    different from ows)(#2747)
>>>>>>>> - Fixed a memory leak associated with not deleting the
>>>> lexer buffer
>>>>>>>>    before parsing certain types of strings. (#2729)
>>>>>>>> - Masking the out-of-range characters to avoid the crash
>>>>>>>>    in the AGG renderer (#2739)
>>>>>>>> - AGG: fix pixmap symbols not drawing if no color was specified
>>>>>>>> (#2736)
>>>>>>>> - Accept WMS requests in which the optional SERVICE param
>>>>>> is missing.
>>>>>>>>    A new test was incorrectly added in 5.2.0 that resulted
>>>>>> in the error
>>>>>>>>    "Incomplete WFS request: SERVICE parameter missing"
>>>>>> when the SERVICE
>>>>>>>>    parameter was missing in WMS requests in which the
>>>>>> SERVICE param is
>>>>>>>>    optional (#2737)
>>>>>>>> - SLD: when creating well known symbols on the fly the
>>>> pen-up value
>>>>>>>>    used should be -99.
>>>>>>>> - Support reading projection parameter for OFC filters (#2712)
>>>>>>>> - Stop configure execution with an error if path to one of
>>>>>> the -config
>>>>>>>>    scripts is invalid (#2710)
>>>>>>>> - Fixed the configure script: failed to detect php5 on ubuntu.
>>>>>>>> (#2365)
>>>>> _______________________________________________
>>>>> mapserver-dev mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>> Daniel Morissette
>>>> http://www.mapgears.com/
