[mapserver-dev] Documentation Updates
Daniel Morissette dmorissette at mapgears.com
Mon Nov 24 14:31:18 EST 2008
Howard Butler wrote:
> Here's some output that's basically a first run to give you an idea
> where things are heading:
> http://iowa.hobu.biz/msdocs/build/html/references/index.html
I really like it!
I presume we'd have a script that runs daily on the server to update the
live docs from SVN?
The nice thing with this approach is that the doc generation script can
be in SVN too and I can easily update and preview changes locally just
by rerunning the script on my machine. The end result is a tree of
static HTML files, correct? So one can also zip up all the files and
have a copy of the docs to browse offline, right? I luv it!  :)
Daniel
Daniel Morissette
http://www.mapgears.com/
