[mapserver-dev] msautotest viewer utility
Thu Oct 2 02:28:45 EDT 2008
On Fri, Sep 26, 2008 at 5:20 PM, Normand Savard <nsavard at mapgears.com> wrote:
> Hi list,
> I created a small add-on to the msautotest tests tool created by Frank.
>  This is a python based script that creates an HTML page to display
> actual/expected images side by side to help developers and testers verify
> results.  There is a third column of images as well which is made of the
> actual and expected images  superimposed on each other.  These images are
> switched in alternance by pressing the button just above to ease  the
> process of  detecting differences.
> You can see a demo at:
> http://dev3.mapgears.com/msautotest/pymod/
> I hope that this will help msautotest users to be less reluctant to use this
> test framework.  Please do not hesitate to comment.
Norm,
This looks fantastic!  I look forward to trying it out on my
own runs when I get home.
Best regards,
