[mapserver-dev] Memory Leak
Paul Ramsey pramsey at cleverelephant.ca
Fri Oct 3 17:08:28 EDT 2008
Looks sane to me. Add a trac ticket (http://trac.osgeo.org/mapserver)
for it, attach the patch, and someone will commit it for you.
P.
On Fri, Oct 3, 2008 at 2:02 PM, Ned Harding <nharding at extendthereach.com> wrote:
> There is a memory leak in msInsertLayer.  The below patch fixes it.  Can
> someone else review it and tell me what I should do with it?
> Thanks,
> Ned.
> Index: S:/3rdParty/GIS/MapServer/mapobject.c
> --- S:/3rdParty/GIS/MapServer/mapobject.c       (revision 15750)
> +++ S:/3rdParty/GIS/MapServer/mapobject.c     (working copy)
> @@ -498,10 +498,20 @@
>      /* Ensure there is room for a new layer */
> -    if (msGrowMapLayers(map) == NULL)
> -        return -1;
> -    /* Catch attempt to insert past end of layers array */
> -    else if (nIndex >= map->numlayers) {
> +    if (map->numlayers == map->maxlayers)
> +                              if (msGrowMapLayers(map) == NULL)
> +                                              return -1;
> +              /* msGrowMapLayers allocates the new layer which we don't
> need to do since we have 1 that we are inserting
> +                              not sure if it is possible for this to be non
> null otherwise, but better to check since this function
> +                              replaces the value */
> +              if (map->layers[map->numlayers]!=NULL)
> +                              free(map->layers[map->numlayers]);
> +              /* Catch attempt to insert past end of layers array */
> +              if (nIndex >= map->numlayers) {
>          msSetError(MS_CHILDERR, "Cannot insert layer beyond index %d",
>                     "msInsertLayer()", map->numlayers-1);
>          return -1;
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
