[mapserver-dev] IGNORE_MISSING_DATA
Daniel Morissette dmorissette at mapgears.com
Fri Oct 17 11:00:30 EDT 2008
Stephen Woodbridge wrote:
>  Also you have to maintain two copies of every
> mapfile, with and without the CONFIG if you are supporting sites with
> multiple versions of mapserver running.
Unless I'm mistaken this would not be required: the CONFIG would simply
be ignored by older versions of MapServer that don't support it.
Daniel Morissette
