AW: AW: AW: [mapserver-dev] speed up layer displayingpostgis-mapserver
SUSANNE susanne.kalliany at tefis.at
Tue Sep 2 14:59:35 EDT 2008
I am using ms4w 2.2.8.
Thanks a lot for your reply.
Greetings from Austria, Susanne Kalliany
BrainDrain wrote:
> I think I know what is your problem. What version of ms4w you're using?
> SUSANNE wrote:
>> 120 tiles are 4*30 tiles (30 tiles for covering the screen, 4 layers).
>> These tiles are empty at the beginning of the project because there are
>> no
>> data. During mapping I have a routine only to update changed tiles.
>> Do you have a better idea?
>> Thanks for helping, Susanne Kalliany
>> -----Ursprüngliche Nachricht-----
>> Von: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von BrainDrain
>> Gesendet: Donnerstag, 21. August 2008 13:46
>> An: mapserver-dev at lists.osgeo.org
>> Betreff: Re: AW: AW: [mapserver-dev] speed up layer
>> why you need 120 tiles at once? for what? 120... it will take a time, but
>> it
>> needless in most cases to generate so many in one operation.
>> and why empty?
>> try to use Proj4 projection string instead of epsg code.
>> SUSANNE wrote:
>>> Excuse me; I sent my previous mail unintentionally!
>>> I am really afraid I am doing something basically wrong; but don't know
>>> how
>>> to go on.
>>> Thanks a lot for your help, Susanne Kalliany
>>> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von Susanne
>>> Kalliany
>>> Gesendet: Donnerstag, 21. August 2008 12:50
>>> An: 'BrainDrain'; mapserver-dev at lists.osgeo.org
>>> Betreff: AW: AW: [mapserver-dev] speed up layer displaying
>>> postgis-mapserver
>>> Sorry for being so nasty.
>>> I did like you told:
>>> LAYER
>>>    NAME zobject1
>>>    GROUP zobject1
>>>    STATUS ON
>>>    MAXSCALE 30000
>>>    TYPE POLYGON
>>>    CONNECTIONTYPE postgis
>>>    CONNECTION 'user=postgres password=susi dbname=tefisdb host=localhost
>>> port=5432'
>>>    DATA  'the_geom FROM zobject1 USING UNIQUE gid1 USING SRID=31282'
>>> 	PROCESSING 'CLOSE_CONNECTION=DEFER'
>>>    PROJECTION
>>>    		'init=epsg:31282'
>>>    END
>>> But nevertheless for drawing 4 (empty) postgis layers -120 tiles 256*256
>>> I
>>> need 3.5 minutes.
>>> Gesendet: Mittwoch, 20. August 2008 21:15
>>> Betreff: Re: AW: [mapserver-dev] speed up layer displaying
>>> postgis-mapserver
>>> -how did you import your layer data into postgres table? did you use
>>> GIST
>>> indexing?
>>> did you use PROCESSING "CLOSE_CONNECTION=DEFER" for your layer?
>>> did you reproject your data?
>>> cluster <gindexname> on <tablename> - just a sql command which you can
>>> run
>>> in context of postgis database using psql console app or pgAgmin utils
>>> or
>>> other software that helps pgsql developers. This command creates
>>> "physically-allocated" gindex which can boost perfomance for large
>>> layers.
>>> I have some layers with 180000-190000 polygons and mapserv draws 256x256
>>> tiles pretty fast for my ajax powered webapp.
>>> SUSANNE wrote:
>>>> Thanks a lot for reply!
>>>> I inserted following line and now postgis query works fine.
>>>> "DATA  'the_geom FROM zobject1 USING UNIQUE gid USING SRID=31282'"
>>>> But I don't get on with optimization.
>>>> On which place do I have to insert: "cluster gindexname on tablename" ?
>>>> I inserted in postgresql.conf:
>>>> # AUTOVACUUM PARAMETERS
>>>> vacuum full
>>>> For me it didn't make any effort.
>>>> And I am worried because there is only one feature in postgis table,
>>>> nevertheless one redraw from database needs more than 2 minute (I
>>>> created
>>>> 30
>>>> png tiles 256*256 RGB 24bit).
>>>> I am afraid I am doing something basically wrong!?
>>>> Many thanks in advance for your kind efforts
>>>> Susanne Kalliany
>>>> BrainDrain
>>>> Gesendet: Dienstag, 19. August 2008 12:31
>>>> Betreff: Re: [mapserver-dev] speed up layer displaying
>>>> postgis-mapserver
>>>> 1. DATA "geom from public.construct >>>>USING UNIQUE [id field name]
>>>> USING
>>>> SRID=[your srid or -1 (not recom.)]<<<<" for all postgis layers
>>>> this solves problem with msPOSTGISLayerRetrievePGVersion
>>>> 2. I use cluster gindexname on tablename & vacuum full. +
>>>> http://www.powerpostgresql.com/Downloads/annotated_conf_80.html
>>>> SUSANNE wrote:
>>>>> Dear Mapserver List!
>>>>> I am developing Mapserver-application (ms4w 2.2.7, postgres 1.8.2)
>>>>> since
>>>>> half a year. Now some debugging and optimization work has to be done.
>>>>> I am doing quite well with programming, but I am not very experienced
>>>>> in
>>>>> installation - optimization issues.
>>>>> I would be very grateful for some hints to answer the follwing
>>>>> questions
>>>>> or how to improve performance generally.
>>>>> 1. How can I get rid of following error:
>>>>> msPOSTGISLayerRetrievePGVersion(): Query error. Error executing
>>>>> POSTGIS
>>>>> statement (msPOSTGISLayerRetrievePGVersion():select
>>>>> substring(version()
>>>>> from 12 for (position('on' in version()) - 13))
>>>>> I did some in internet searches but I could'nt take head or tale of
>>>>> it.
>>>>> 2. Should I increase max_buffer in postgresql.conf?
>>>>> I found the tip
>>>>> (http://mapserver.gis.umn.edu/docs/howto/optimizevector/html2pdf), but
>>>>> I
>>>>> don't have such an item in my postgres.conf file and also don't know
>>>>> which
>>>>> value I have to set.
>>>>> 3. How to improve displaying of 5 postgres-supported editable layer.
>>>>> It
>>>>> takes some time even when these layers are empty!?
>>>>> (Installation uses kaMap in javascript-php enviroment)
>>>>> thanks a lot, Susanne Kalliany
>>>> View this message in context:
>> http://www.nabble.com/speed-up-layer-displaying-postgis-mapserver-tp19032703
>>>> p19047825.html
>>>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>> p19076195.html
>> p19087077.html
View this message in context: http://www.nabble.com/speed-up-layer-displaying-postgis-mapserver-tp19032703p19276270.html
