[mapserver-dev] Problem with metadata
Yewondwossen Assefa yassefa at dmsolutions.ca
Wed Sep 3 11:08:21 EDT 2008
Hi There,
  I have done some quick tests removing/setting/saving the metadata but
could not reproduce the cases that you have seen.  I could not also
locate something obvious in the code that could explain the behavior you
see. If there is  some way I can  replicate it locally with some
dataset/map, I am will to look into it more.  Note that all tests I have
done are with the 5.2 version.
Best Regards,
Tommy Roughol wrote:
> Hello everyone,
> I have a problem with PHP Mapscript. When I add or remove some
> metadatas, sometimes metadatas are removed without reasons.
> For instance, I have a metadata "description", and when I do
> "$oLayer->removeMetaData('toto');"or "$oLayer->setMetaData('toto',
> 'titi');", the metadata description is deleted, but not always, sometimes.
> Is there an issue ?
> Is this a known bug ?
> I had to use a hack like this to avoid this problem :
> // I save my metadata Description
> $szLayer = $oLayer->getMetaData('DESCRIPTION');
> // i remove metadatas
> if($oLayer->getMetaData('REPORT_BIRT') != '') {
> $oLayer->removeMetaData('REPORT_BIRT');
> if($oLayer->getMetaData('ID_BIRT') != '') {
> $oLayer->removeMetaData('ID_BIRT');
> if($oLayer->getMetaData('OUTPUT_BIRT') != '') {
> $oLayer->removeMetaData('OUTPUT_BIRT');
> // i save metadata to avoid the strange remove that happens sometimes
> $oLayer->setMetaData("DESCRIPTION", $szLayer);
> $oMap->save($szPathMap);
> Thanks a lot
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
