[mapserver-dev] Attempt to fix #1706
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Wed Sep 17 08:18:01 EDT 2008
Hello
Could the following patch be applied?
http://trac.osgeo.org/mapserver/attachment/ticket/1706/mapsvg.c.diff
Anyway, there is a minor issue with this patch. Since it writes all path
coordinates with 2 digits after the comma, it inflates the file size of
teh SVG file, even if full resolution is not wanted. Unfortunatly, I do
not know, how to guess this setting from within function
mapsvg.c:imagePolyline(). I could make the variable bFullRes module wide
and set the parameter from mapsvg.c:msTransformShapeSVG().
Regards,
Peter
R3 GIS
http://www.r3-gis.com
