[mapserver-dev] Attempt to fix #1706
Yewondwossen Assefa yassefa at dmsolutions.ca
Wed Sep 17 13:48:59 EDT 2008
Peter,
  I have reviewed and done a couple of modifications to the patch
proposed in the bug. Please verify the comments in the bug. I would then
commit the changes.
Best Regards,
Peter Hopfgartner wrote:
> Hello
> Could the following patch be applied?
> http://trac.osgeo.org/mapserver/attachment/ticket/1706/mapsvg.c.diff
> Anyway, there is a minor issue with this patch. Since it writes all path
> coordinates with 2 digits after the comma, it inflates the file size of
> teh SVG file, even if full resolution is not wanted. Unfortunatly, I do
> not know, how to guess this setting from within function
> mapsvg.c:imagePolyline(). I could make the variable bFullRes module wide
> and set the parameter from mapsvg.c:msTransformShapeSVG().
> Regards,
> Peter
> R3 GIS
> http://www.r3-gis.com
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
