[mapserver-dev] Attempt to fix #1706
Yewondwossen Assefa yassefa at dmsolutions.ca
Wed Sep 17 15:58:03 EDT 2008
Peter Hopfgartner wrote:
> AFAIKT, it looks perfectly fine to me.
It is committed in the in main trunk.  Thanks.
> Thanks,
> Peter
> Yewondwossen Assefa wrote:
>> Peter,
>>  I have reviewed and done a couple of modifications to the patch
>> proposed in the bug. Please verify the comments in the bug. I would
>> then commit the changes.
>> Best Regards,
>>> Hello
>>> Could the following patch be applied?
>>> http://trac.osgeo.org/mapserver/attachment/ticket/1706/mapsvg.c.diff
>>> Anyway, there is a minor issue with this patch. Since it writes all
>>> path coordinates with 2 digits after the comma, it inflates the file
>>> size of teh SVG file, even if full resolution is not wanted.
>>> Unfortunatly, I do not know, how to guess this setting from within
>>> function mapsvg.c:imagePolyline(). I could make the variable bFullRes
>>> module wide and set the parameter from mapsvg.c:msTransformShapeSVG().
>>> Regards,
>>> Peter
>>> R3 GIS
>>> http://www.r3-gis.com
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
