[mapserver-dev] msautotest viewer utility
Paul Ramsey
pramsey at cleverelephant.ca
Fri Sep 26 11:37:13 EDT 2008
That's great! One other thing I would ask for is the actual test
status (pass/fail) somewhere so you can quickly skip the ones that
were automatically judged a "pass".
On Fri, Sep 26, 2008 at 8:20 AM, Normand Savard <nsavard at mapgears.com> wrote:
> Hi list,
> I created a small add-on to the msautotest tests tool created by Frank.
> This is a python based script that creates an HTML page to display
> actual/expected images side by side to help developers and testers verify
> results. There is a third column of images as well which is made of the
> actual and expected images superimposed on each other. These images are
> switched in alternance by pressing the button just above to ease the
> process of detecting differences.
> You can see a demo at:
> http://dev3.mapgears.com/msautotest/pymod/
> I hope that this will help msautotest users to be less reluctant to use this
> test framework. Please do not hesitate to comment.
> Norm
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
