[mapserver-dev] msautotest viewer utility
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Fri Sep 26 12:31:22 EDT 2008
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
> Normand Savard
> Sent: 26 September, 2008 11:21 AM
> To: mapserver-dev at lists.osgeo.org
> Subject: [mapserver-dev] msautotest viewer utility
> Hi list,
> I created a small add-on to the msautotest tests tool created
> by Frank.
> This is a python based script that creates an HTML page to
> display actual/expected images side by side to help
> developers and testers verify results.  There is a third
> column of images as well which is made of the actual and
> expected images  superimposed on each other.  These images
> are switched in alternance by pressing the button just above
> to ease  the process of  detecting differences.
> You can see a demo at:
> http://dev3.mapgears.com/msautotest/pymod/
> I hope that this will help msautotest users to be less
> reluctant to use this test framework.  Please do not hesitate
> to comment.
Excellent work Norm!  This would be great to commit to trunk, IMHO.
I would make a list of links to be able to select a mapfile to test
(i.e. sos.map, wcs_simple.map, etc.).  This would allow developers to be
able to test against a given mapfile.
Again, excellent!  I think this is a valuable add-on, especially for the
visuals.
..Tom
