[mapserver-dev] msautotest viewer utility
Normand Savard nsavard at mapgears.com
Fri Sep 26 16:39:25 EDT 2008
Kralidis,Tom [Burlington] wrote:
> I would make a list of links to be able to select a mapfile to test
> (i.e. sos.map, wcs_simple.map, etc.).  This would allow developers to be
> able to test against a given mapfile.
Tom,
I'll add this.
I also want to add the perceptualdiff result as well for each image and
a field to set a threshold value to filter the images in the viewer.
For instance supposed you only want to see images that have a pdiff
greater than 12000 pixels.
The other enhancement I could see is to display Geotiff image as well.
Do someone has an idea?
Norm
