[mapserver-dev] Time for a 5.2.1 release?
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Mon Sep 29 09:17:40 EDT 2008
I would like to see http://trac.osgeo.org/mapserver/ticket/2657 fixed (I believe the patch will do it), otherwise, I thank 5.2.1 this week is a good idea.
..Tom
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org on behalf of Daniel Morissette
Sent: Mon 29-Sep-08 09:15
To: 'MapServer Dev Mailing List'
Subject: [mapserver-dev] Time for a 5.2.1 release?
We seem to have a good set of fixes in the 5.2 branch in SVN. What do
you all think of a 5.2.1 release this week with what's in there now?
Daniel
Current Version (SVN branch-5-2)
- Fixed bug when QUERYMAP hilite color is set and the shape's color in a
   layer is from a data source (#2769)
- PHP paste image should also work with AGG (#2682)
- Correct allocation error in mapmssql2008.c (#2768)
- Removed comma to correct WCS 1.1 Coverages formatting in payload
directory.
   (#2764)
- Correct bug when LABEL_NO_CLIP in combination with minfeaturesize (#2758)
- Fix a label size computation for AGG bug when scalefactor is used (#2756)
- Got rid of misleading errors about OWS SERVICE not being compiled in
   when a OWS request is sent that includes mode=map (or other mode value
   different from ows)(#2747)
- Fixed a memory leak associated with not deleting the lexer buffer
   before parsing certain types of strings. (#2729)
- Masking the out-of-range characters to avoid the crash
   in the AGG renderer (#2739)
- AGG: fix pixmap symbols not drawing if no color was specified (#2736)
- Accept WMS requests in which the optional SERVICE param is missing.
   A new test was incorrectly added in 5.2.0 that resulted in the error
   "Incomplete WFS request: SERVICE parameter missing" when the SERVICE
   parameter was missing in WMS requests in which the SERVICE param is
   optional (#2737)
- SLD: when creating well known symbols on the fly the pen-up value
   used should be -99.
- Support reading projection parameter for OFC filters (#2712)
- Stop configure execution with an error if path to one of the -config
   scripts is invalid (#2710)
- Fixed the configure script: failed to detect php5 on ubuntu. (#2365)
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
