[Fwd: Re: [mapserver-dev] Any reaction to the 5.4 release plan?]
Steve Lime Steve.Lime at dnr.state.mn.us
Wed Feb 4 12:54:55 EST 2009
BTW I have started a 6.0 release plan at:
  http://trac.osgeo.org/mapserver/wiki/60ReleasePlan
Hopefully we can add meat to it at the sprint...
Steve
>>> On 2/4/2009 at 11:17 AM, in message <4989CDC5.8090803 at swoodbridge.com>, Stephen
Woodbridge <woodbri at swoodbridge.com> wrote:
> Argh, this was supposed to go to the list.
> -------- Original Message --------
> Subject: Re: [mapserver-dev] Any reaction to the 5.4 release plan?
> Date: Wed, 04 Feb 2009 11:12:35 -0500
> From: Daniel Morissette <dmorissette at mapgears.com>
> To: Stephen Woodbridge <woodbri at swoodbridge.com>
> References: <498956DD0200008F000204B0 at co5.dnr.state.mn.us>
> <4989AD43.6070107 at dmsolutions.ca> <4989B2FB.3000802 at mapgears.com>
> <4989BDB9.8030102 at swoodbridge.com>
> Steve, you sent this off-list, but I presume you meant to CC this to the
> -dev list in support of not changing the dates currently in the release
> plan?
> Stephen Woodbridge wrote:
>> Daniel,
>> You have put into works exactly my concerns on this. I was thinking that
>> we should start a 6.0 release plan so that high(er) risk changes can be
>> pushed to that plan. My thought was to help set appropriate expectations
>> for all involved. But I think your words better voice my concern than
>> what I was going to propose above as an action plan to avoid the risk.
>> -Steve W
>> Daniel Morissette wrote:
>>> Sorry for the lack of reply to your initial email. I liked the dates
>>> that you had proposed (to release what's currently in SVN trunk by
>>> early March) and didn't have much to add.
>>> With respect to Assefa's comment, I thought it would be best to wrap
>>> up 5.4 before the sprint so that we can focus on new/6.0 stuff in
>>> Toronto. If 5.4 is still in the way and the source has not been
>>> branched yet for 5.4 then I fear that will reduce our ability to make
>>> real progress in the code sprint (i.e. major changes just before a
>>> release is dangerous).
>>> Daniel
>>> Yewondwossen Assefa wrote:
>>>> I was actually checking it and trying to understand if any of the
>>>> work planned in Toronto will be part if the 5.4 release. From this
>>>> schedule, It seems that it won't. I would propose to do a feature
>>>> freeze at the end of the code sprint or  shortly after so some things
>>>> can fit in this 5.4 release.
>>>> My main goals for the code print:
>>>>   - finalize my part for the 5.4 release
>>>>   - engage discussion the rendering (mainly pdf) in terms of having
>>>> something suitable for a profession printing needs.
>>>> Assefa
>>>> Steve Lime wrote:
>>>>> Not sure what absolute silence means...
>>>>>   http://trac.osgeo.org/mapserver/wiki/54ReleasePlan
>>>>> Steve
>>>>> _______________________________________________
>>>>> mapserver-dev mailing list
>>>>> mapserver-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
