[mapserver-dev] PROJ4 and EPSG database
Yewondwossen Assefa yassefa at dmsolutions.ca
Thu Feb 12 13:29:06 EST 2009
Frank Warmerdam wrote:
>>> Folks,
>>> I would point out that MapServer already has a concept of axis ordering
>>> implemented for WCS.  Of note are the msAxisNormalizePoints() and
>>> msAxisDenormalizePoints() functions in mapproject.c.  These are tied to
>>> epsgaxis= settings which can be "en" for easting,northing or "ne" for
>>> northing,easting.
>>> Currently mapfile.c's proj init function has a special case to set this
>>> parameter for EPSG urn's in a particular range.  In the short term I
>>> think this is the logical mechanism to extend when working on WMS 1.3.0.
>> Frank,
>> This is exactly how I am implementing the proj support for wms1.3.0:
>> extend the functions to support more CRS codes and the AUTO2.  The
>> only difference that I saw from WCS1.1 would be to allow all EPSG
>> projection strings (given as Urns or just ESPG:XXXX) to pass though
>> the functions to set the axes order for those particular ESPG ranges.
> Assefa,
> I do not think we can have EPSG:4326 be assumed to be lat/long for all
> services, so some mechanism will need to be put in place to alter the
> behavior in WMS 1.3 mode.  Possibly you could alter EPSG: to EPSGA: in
> the WMS 1.3 handler code and we could look for that.   Or even replace
> the EPSG: with the corresponding URN before calling the
> msLoadProjectionString() function.  What I don't want is for the axis
> stuff to be altered when folks have EPSG: metadata set or with WMS 1.1.
> Best regards,
Frank,
I made sure that I did not modify the behavior for other services
regarding msLoadProjectionString and the ESPG.  What I have implemented
for now (not committed yet) is that WMS 1.3.0 uses a function that only
checks the ESPG:XXX syntax (and does the axes orientations settings). If
the string is not of the ESPG:XXX type, It goes to msLoadProjectionString.
 From the tests I have done, nothing has changed for WMS 1.1.1 for
example.
Best Regards,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
