[mapserver-dev] geometry in getfeatureinfo wms request
bartvde at osgis.nl bartvde at osgis.nl
Fri Jan 9 09:49:20 EST 2009
But that's not his question.
I was wondering the same yesterday, and looking at the code I could not
find any clues as to why GetFeatureInfo does not output the geometry
anymore.
Steve, Assefa, Daniel, do you guys have a clue? TIA.
Best regards,
Bart
> Hi,
> Instead, you could use a getfeature request that returns geometry by
> default. Theses requests can give you response in GML which is far more
> structured than getfeatureinfo requests result.
> Alexandre
> godofredo contreras wrote:
>> Hi:
>> I have trying to get mapserver returning the geometry in
>> getfeatureinfo request, I set DUMP TRUE and the request
>> returns attribute data in gml format but not the geometry.
>> How can I make mapserver wms return the geometry
>> with info_format=application/vnd.ogc.se_xml?
>> Thanks in advance
>> Godofredo Contreras
>> Windows Live™: Keep your life in sync. See how it works.
>> <http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t1_allup_howitworks_012009>
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Alexandre Dubé
> Mapgears
> www.mapgears.com
