[mapserver-dev] rfc49: call for vote
Stephen Woodbridge woodbri at swoodbridge.com
Sun Jan 18 13:59:37 EST 2009
Thomas,
Does this implement all the new features that you used in you sample OSM
mapfile you posted a while back? If not can you enumerate those that
would not get implemented. Which by the way work very nicely. I built a
mapfile based on that rev in that sandbox ans I'm very impressed with
the quality of the rendering and the simplicity of the mapfile.
You can see it here: http://imaptools.com/leaddog-new.html
-Steve
thomas bonfort wrote:
> Hi devs,
> I'd like to get this in for 5.4:
> http://mapserver.org/development/rfc/ms-rfc-49.html
> wrapping up the comments from the review period, I think there isn't
> any issue preventing a vote:
> * possible values for LABELMETHOD (the default is to use cog) :
> awaiting implementation, very probably postponed to after 5.4 (unless
> Steve planned to implement this soon ?)
> * labelObj for layer: implementation postponed to after 5.4
> * fractional values also for pattern,gap, offset:  a good candidate
> for 6.0 (when pattern and gap would be moved to the styleObj?)
> * there was concensus for adding parametered scaling, usefull for
> thematic mapping (eg size proportional to a feature attribute)
>    - by allowing simple expressions, eg SIZE  ( 18 + [poptotal] * ((
> 43-18)/(5000-30000))  )
>    - or by adding pseudoitems at the layer level:
> PSEUDOITEM
>  'mySize' (mrange([itemname], mininput, maxinput, minoutput,
> maxoutput))
>  'myText (commify(round([itemname], 2)) + ' ac')
> END
> LABELITEM 'myText'
> CLASS
>  STYLE
>    COLOR 255 0 0
>    SIZE [mySize]
>  END
>  LABEL
>  END
> END
> this enhancement will be addressed in a specific rfc.
> best regards,
> Thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
