[mapserver-dev] pdf output development?
boesiii boesiii at yahoo.com
Mon Jan 19 16:53:29 EST 2009
Brent,
I am interested in trying to create a PDF output image similar to the ones
you created but I am not sure how to proceed.   I have a basic mapserver
setup.  I am not sure if I have any PDF libraries installed or what a PDF
library is or used for.  I see the text that I need to add to the map file
but I don't know if I need other files.
What other files or software do I need to install to produce PDF's?
Thanks,
Ed
View this message in context: http://n2.nabble.com/pdf-output-development--tp2120010p2183666.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
